02-18-2021, 11:22 AM | #1 |
Frame Differences
Quick question - I want to put a 73-80 cab and front clip on a 81-87 frame. My understanding is that you need to use the mounts that go with the frame. Any other differences that I would run into, or is that it? New to these squares and I want to make sure before pulling the trigger on the frame!
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e 1970 Chevrolet K5 Blazer - Project 1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4 1969 GMC Suburban - 5.3 LS, 4L60e |
02-18-2021, 11:37 AM | #2 |
Re: Frame Differences
Unless you're willing to do some fabrication, the front bumper will need to stay with the frame. The frame horns are different where the bumper attaches.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
02-19-2021, 01:23 PM | #3 |
Proud Vet that loves the USA
Parking brake cabe routing is different as well.
Bubba |
02-21-2021, 12:46 AM | #4 |
I put a 75 body on an 80's frame. Two of the bolt holes for the bed didnt line up but it was easy enough to drill the holes into the frame. I suspect a 73-74 bed would also have the same issue.
