07-10-2023, 08:00 PM | #1 |
1960 GMC Burb
60 Burb 305 V6 Motor Mounts
So what is everybody doing for new or replacement motor mounts for the 305 V6 ?
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT |
07-10-2023, 09:17 PM | #2 |
Re: 60 Burb 305 V6 Motor Mounts
Steele Rubber will re-vulcanize your old ones for $155
https://www.steelerubber.com/motor-m...ice-70-2008-11 Others have used Anchor 2337; just have to drill a hole in the middle. I have not used it personally but looked into the alternatives and this came up.
MusicMan70 1961 GMC Suburban |
07-10-2023, 11:28 PM | #3 | |
1960 GMC Burb
Thank you ..so the one on the left is a 2337.. is the one on the right the standard mount ?
07-10-2023, 11:54 PM | #4 |
Yes that’s correct. Right side is the factory mount.
Tags |
305 v6, motor mounts |
