Old 02-29-2024, 02:02 PM   #1
Ricks1971
Ricks1971's Avatar
difference between a 67 C10 tank and a 72 C10 fuel tank
I am changinthe the fuel tank out of my 67 C10 and bought a aftermarket tank and I think its a 72 C10 tank and the bolts don't match up? I thought the tanks were the same from 67 to 72?
Ricks1971 is online now   Reply With Quote
Old 02-29-2024, 02:20 PM   #2
michael bustamante
michael bustamante's Avatar
Re: difference between a 67 C10 tank and a 72 C10 fuel tank
71-72 tanks have vapor lines attatched to them, that should be the only difference as far as i know
1967custom
michael bustamante is offline   Reply With Quote
Old 02-29-2024, 02:36 PM   #3
58 Special
Filler tube is different size on 72 I think as cap is vented
58 Special is offline   Reply With Quote
Old 02-29-2024, 08:57 PM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Seems to me a 71 fuel tank cap fits a 72. Could be wrong. But the caps were different, you're right, the 72 cap is "vented". I wonder why really, aren't the tank and charcoal parts the same as a 1971? Perhaps GM just figured the vented cap was simply more better.
1971 EEC cap is actually vented, from what I understand. They just release at a higher PSI than 72.
Other then that, for what worth, 1972 senders and fuel pumps are often different then 1971 and prior. Both have ports for a return line.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
