Old 10-07-2023, 02:16 PM   #1
Bunky
Question 4 speed Transmission interchange?
I have a Creeper gear transmission in my 67 C15 . I would like to swap that out with a Saginaw 4 speed. Can I just swap these out and keep the bellhousing,clutch assembly intact. Or is the splines different on the Saginaw?
Bunky is offline   Reply With Quote
Old 10-08-2023, 08:17 AM   #2
cadillac_al
Re: 4 speed Transmission interchange?
I am 98% sure the splines are the same.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is online now   Reply With Quote
Old 10-08-2023, 08:38 AM   #3
geezer#99
geezer#99's Avatar
Spline should be the same but the trans input bearing housing diameter might be different.
Info in here.
https://www.streetmusclemag.com/tech...t-bellhousing/
Old 10-08-2023, 05:29 PM   #4
kwmech
Nose cone should be the same being an SM420. I would however check the bolt pattern
saginaw 4 speed, sm465
