Old 10-08-2023, 06:23 PM   #1
Angrywood
62 dash harness wire question
im changing out the dash harness with a AAW on my 62 c10. i removed a orange and a white wire from under and inside the steering column area. Whats that for? both wires connect to the same piece. I got distracted and dont know what wire goes on what tab. Any ideas? its not the plug that is for the turn signal switch. thnx
Angrywood is offline   Reply With Quote
Old 10-08-2023, 06:56 PM   #2
Angrywood
Re: 62 dash harness wire question
ok i think i figured it out. its the break light switch. does it matter which color goes on what tab? on the wire diagram i saw i believe orange on the bottom?
Old 10-08-2023, 07:47 PM   #3
SkinnyG
SkinnyG's Avatar
Does not matter which tabs you use for the brake switch. And it's "clocking" all changes if you adjust the switch.
Recently did the AAW in my '61, plus incorporating a complete LS-swap.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 10-08-2023, 10:07 PM   #4
Angrywood
thanks skinny.... no clocking... just took me a bit to find the wiring diagram and figure it out. no clocking just removed and put the new wires on...
Old 10-10-2023, 05:42 PM   #5
Angrywood
heres another question....
on my old fuse block there was a wire connected to the unfused ignition tab that ran I believe to the ignition switch. was hard to tell with the spaghetti bowl of wires going on. after the AAW harness is in, i dont see what to connect to that spot if anything? what is the unfused ignition tab for?
Old 10-10-2023, 08:22 PM   #6
SkinnyG
SkinnyG's Avatar
Maybe someone "fixing" a wiring problem by re-wiring it?
Old 10-10-2023, 10:38 PM   #7
Angrywood
ya... there was alot of that going on... thats why i just did the whole harness instead of trying to figure it out wire by wire
Old 10-11-2023, 12:55 AM   #8
SkinnyG
SkinnyG's Avatar
I so much extra wiring with the LS swap, I could have done a cleaner install without the AAW kit. However, it IS a good kit, and all the truck thinking is already done for you.
