02-18-2024, 08:40 PM | #1 |
Another LED bulb question
Whatever led bulb I try to install on the front turn signals it never works. If I turn on the blinker it just stays lit and the rears (led) don’t blink at all. I have the special blinker switch. It works fine if I have the leds in the rear and normal bulb up front. I have cleaned off all the metal to metal connections so I am pretty sure it is well grounded. Is there another way to ground it that I am missing? It’s a 62 c10 pickup.
02-18-2024, 10:11 PM | #2 |
Re: Another LED bulb question
You can get a no-load flasher module to replace the regular one, or install load resistors. Google or look on Amazon.com for LED load resistors. Or what I do is use regular bulbs in the front and LED in back. The advantage of LED bulbs is instant-on for your brake lights giving you more safety, there really isn't any advantage for using in any other position on the truck. If you use a paperclip to plug and unplug into the flasher module socket and with a helper notice it works OK, then that would determine the flasher module is not suitable. Wear leather gloves when handling the paper clip in case it gets hot.
Here is a no-load flasher module, but note that I did not try it with all LED lights, I just suspect it will work. It's returnable if it doesn't work out. https://www.amazon.com/Keep-Clean-10...dp/B00H8KDON0/ Last edited by dmjlambert; 02-18-2024 at 10:23 PM. |
02-18-2024, 10:32 PM | #3 |
I have the non load flasher. The only reason I am looking for LED blinkers up front is so that they would be brighter.
02-18-2024, 10:39 PM | #4 |
Perhaps the no-load flasher you have is not working properly, or you need load resistors, or you might try incandescent 2357 bulbs which are brighter.
02-18-2024, 11:03 PM | #5 |
I don’t have it in front of me now but the amber bulb that is currently in the truck has a 4 digit part number that starts with a 3. If the led bulb is not going to be brighter than its not worth the trouble of getting a resistor and LEDs
02-18-2024, 11:27 PM | #6 |
My mistake for assuming you might have an 1157 bulb. There are many different bulbs that are similar in size and can interchange. Some are brighter than others.
02-18-2024, 11:44 PM | #7 |
My Nephew put a-Lot of LED light on his truck.
After he added a few,. We had to add some filters. I am not sure what kind. Here is an example link. Link: https://www.ebay.com/itm/22511000101...65a8eaf5faa12f
02-18-2024, 11:47 PM | #8 |
02-18-2024, 11:48 PM | #9 | |
02-19-2024, 12:30 AM | #10 |
When you find out the type of regular bulb you have that is not so bright, let us know and perhaps there will be a different bulb that will work better.
02-19-2024, 01:01 AM | #11 |
That’s what I was thinking thanks. When the storm we are having is over I will take a look.
