Old 03-22-2024, 11:40 AM   #1
straight6chevyguy
straight6chevyguy's Avatar
Wanting to swap to a different manual transmission
Hello everyone I have a 1998 Chevy 1500 2wd 5 speed manual.
The input shaft bearing on the transmission is badly worn I'm still driving the truck
I know it needs to be taken care of sooner or later and I might be taking the truck on a longer then usual trip in the near future. For a long time I have had problems with the clutch not working smoothly and I'm starting to hear a rattling noise when I'm in 4th gear under load.
I was thinking about rebuilding the transmission but I was also thinking I would like to upgrade to a more heavy duty tranny preferably with a granny gear. The gearing it has now is ok but I really would like a granny 1st for hauling firewood on the farm which I use the truck for often.
Do any of you guys know of a good 5 speed with granny 1st that will bolt up to the 4.3?
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1998 chevy c1500 4.3L 5speed (My current driver)
2002 Chevy s10 4.3L auto 4x4
1971 mercury monterey wagon 400 auto
To many projects!
straight6chevyguy is offline   Reply With Quote
Old 03-26-2024, 08:07 PM   #2
Tom
driving is in my blood
Tom's Avatar
Re: Wanting to swap to a different manual transmission
NV4500 to replace your NV3500. Granny first. Still overdrive. Still 5sp. Came in these trucks stock in the 2500-3500
Old 03-28-2024, 01:13 AM   #3
straight6chevyguy
Thank you, now I know what to look for.
Now to find one lol.
To many projects!
Old 04-01-2024, 09:00 AM   #4
Or, give up O/D for an even more stout 4spd from a '90 up. I've had the NV4500 fail three different times. Never heard of the 4spds failing
Old 04-01-2024, 11:41 AM   #5
straight6chevyguy
That is a thought but considering this truck is only a V6 powered half ton I think an HD 5 speed would be adequate for my needs.
If I was building this truck for heavy towing or whatever yeah I would probably opt for the 4 speed
To many projects!
