01-09-2024, 01:04 PM | #1 |
Junior Member
Need help dismantling spring hanger
1966 GMC Suburban 4WD
I'm having trouble removing the pin/ bolt from a frame bracket that connects the front leaf spring rear hanger to the frame. It looks to be threaded but can only get it to turn just a bit. I've used PB Blaster but have not tried heating it yet. Is it threaded or does it need to be pressed out? C catalog does not appear to show it being threaded. I would like to remove it before sandblasting the frame. Here are a couple of pictures.
1964 Chevy Suburban 4x4 1966 GMC Suburban 4x4 |
02-23-2024, 06:57 PM | #2 |
Born Psycho
Re: Need help dismantling spring hanger
you need a good torch and heat the pi$$ out of the bracket and it should come out. if you're replacing the stud heat it up and smack it with a BFH.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
02-24-2024, 12:11 PM | #3 |
All about them K’s
+1 they can be a real pita, especially as these old beasts continue to age.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
03-05-2024, 12:47 AM | #4 |
Junior Member
Thanks for the input. More PB Blaster, some heat and was able to unscrew them. Fine threads on outer ends with coarse threads in the middle.
03-07-2024, 05:49 PM | #5 |
I replaced the bushings also on my 59. I used a ball joint installer remover to push it all out. Your bushings are probably wore also.
I push later model rubber bushings out same way. No burning them out.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
