Old 03-21-2024, 05:54 PM   #1
zigvs
3-5 drop with a stock rear spring rate
I lowered my truck several years ago with drop spindles and rear coils and spring locator kit.The rear spring is to soft,So I tried new rear springs and they are soft too.Does someone make rear coil lowering springs that have the stock spring rate?So I can still load **** in the back?Thanks
zigvs is offline   Reply With Quote
Old 03-21-2024, 06:27 PM   #2
geezer#99
geezer#99's Avatar
Re: 3-5 drop with a stock rear spring rate
Try some of these.
https://www.partsengine.ca/2445-vp-f...SABEgKIo_D_BwE
Old 03-22-2024, 10:22 PM   #3
novaX522
I have 2” drop springs in the rear of mine. I went with air bags inside the coils. I found a bag that was 5.5”x 8.5” br AirLift that fit my springs.
I also have a new set of bags that are 5.5”x 6” that were too short for my springs. I can find the part numbers if you are interested.
novaX522 is offline   Reply With Quote
Old 03-22-2024, 10:40 PM   #4
novaX522
I found the part number for the 5.5”x8.5”, it is 60924. The smaller bags I have are part number 60811.
I did have to drill a hole through the upper spring clamp and frame for the air line to the bag. It was easy.
