Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 03-05-2024, 09:37 AM   #1
jaycrew1
jaycrew1's Avatar
Airbag light 17 silverado
I have a 2017 Chevy Silverado 4x4 1500 Crew cab truck. The airbag error light is on in the dash and message center. Local mechanic ran codes and found out that there was a bad airbag/collision sensor and a seat belt code. I replaced the faulty sensor under the core support. We cleared the code, just to have it to return again. Does anyone know what to look for when there is a seat belt problem. Truck has 110,000 mile on it. the code just came on 9,000 miles ago. Thanks
jaycrew1 is offline   Reply With Quote
Old 03-27-2024, 12:01 AM   #2
michael bustamante
michael bustamante's Avatar
Re: Airbag light 17 silverado
Seat belts are grounded. May e the ground wore stripped out of the mounting eyelet.
1967custom
michael bustamante is offline   Reply With Quote
Old 04-05-2024, 07:57 AM   #3
KShortell
KShortell's Avatar
One key thing to remember is that codes indicate a problem in a circuit, not always a specific diagnosis. The sensor could have been faulty, but so could a wire, etc. Old-school diagnostic basics aren't dead yet. ;-)
Check wiring harnesses for damage, grounds for corrosion, etc. Good luck!
Semper Paratus
KShortell is offline   Reply With Quote
