Old 08-26-2020, 01:47 AM   #1
cstanley
cstanley's Avatar
New Seat Swap for the old K5 - Acadia 2nd Row
It’s been a while since posting, but hey.
I thought I’d show a recent experiment on my Sportbird. I’m about to set it up for a bit of occasional overlanding and regular camping, and really wanted some seats that fold. But they also had to slide. And recline. And leather would be nice.
So, I picked up a set of 2019 GMC Acadia 2nd rows from an “All Terrain” edition to get brown.
Pretty easy to mount. A few holes in front and some rectangle tube at back.
They sit lower than stock. I tried as low as possible so that they were lowest they could be when folded. They are probably an inch further back than stock “I had previously modified stock to sit almost. 2” back - best mod I ever made.)
Seats are comfy, and I liked them because the bolsters were a bit larger compared to other fold-flat 2nd rows. The squared off backs are OK, since that is part of platform when folded flat.
Trying to decide whether to keep them. Color is an older corvette color, “Kalahari” and trying to decide whether to dye to match original Saddle, or dye everything else to match the Kalahari.
Anyway, I’m happy with them for now.
I have the rears as well, but they are about 8” too narrow so need to figure that out...
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 08-26-2020, 01:51 AM   #2
cstanley
cstanley's Avatar
Re: New Seat Swap for the old K5 - Acadia 2nd Row
A few more.
Old 08-26-2020, 10:08 AM   #3
68panelman
68panelman's Avatar
Those look sharp, and I don't like many modern things in these old blazers, but they look nice. I would have to raise them higher though
68panelman is offline   Reply With Quote
Old 08-26-2020, 12:08 PM   #4
Yukon Jack
Yukon Jack's Avatar
Very interesting!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-26-2020, 12:19 PM   #5
mister.freeze
mister.freeze's Avatar
those are the stock sliders? It realy moves forward! I had to build sliders for mine to move that far
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 08-26-2020, 04:27 PM   #6
cstanley
cstanley's Avatar
They are the sliders that are on the Acadia seats, yes. I think the older models (pre 2018 i think) had really long nasty and complex sliders that would keep them from being very usable. But 2018+ have shorter cleaner sliders.
Old 04-24-2024, 12:14 PM   #7
notoriousnsb
CStanley - I'm looking to upgrade my original seats to something more modern. Originally I was going to use the 2007-2014 Tahoe/Yukon second rows, but after seeing your pictures, I'm now considering the Acadia seats instead as I really like the way yours turned out with the slider option.
-Did you end up staying with these seats for the past four years and are you still pleased with function and usage of them?
-Are you happy with the height in regards to comfort since you intentionally kept them a bit lower than our factory ones?
-When mounted in the same position as you did, do they slide farther back than the factory driver seat in regards to legroom? I'm fairly tall so more legroom would be ideal.
-Did you have to cut the Acadia slider rails off in the back as I looked at a pair recently and it appears that the inner rail is longer than the outer rail for the seats. Looks like maybe its just a second piece that can be removed on the longer side, but not sure? Does that 'extension piece just unbolt from the rail? See attached picture for details on that.
-How did the Acadia seat slider rail bolt holes line up with our factory seat holes? Did you have to drill out new holes in our floor or were you able to modify the slider rails enough to avoid that? Since our driver and passenger side bolt holes are in different locations in the rear I'm just trying to decide how this install could be done without drilling new holes in the my floor.
-Is your passenger side 90 degree angle iron bolted in to the original floor pan two "centered" holes that held the seat flip up latch release? What is the left rail of passenger seat bolted to in the rear?
-Did your Acadia seats come with seat heaters, and if so were you able to wire them in without a computer controller?
I have roll bar mounted three point seat belts so that is one area I don't have to consider for this install.
Any other gotchas that I should know?
Thanks in advance!
Last edited by notoriousnsb; 04-24-2024 at 12:16 PM. Reason: Picture didn't show up
notoriousnsb is offline   Reply With Quote
Old 04-24-2024, 08:00 PM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Thanks in advance!
Subscribing. As my '71 Jimmy needs seats badly.
'68OrangeSunshine is online now   Reply With Quote
acadia, blazer, seats, swap
