11-21-2016, 01:35 AM | #1 |
Building an engine with some storage questions
I was making a mountain of Chevy 350 parts in my house for a while now and decided to go ahead and use them and build my motor, or atleast the bottom end. Well now the bottom end is done (need some cylinder heads) and have the motor bagged, my question is, is it okay to store this motor with just the bottom end done for a little while I look for heads? I used thick assembly lube from CRC and Lunati, will this still be okay in a few weeks for start up or even a month?
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
11-21-2016, 02:05 AM | #2 |
Re: Building an engine with some storage questions
Yes, it will be fine. I've built motors & stored them for extended periods, just keep it clean & dry. (keep the cylinders oiled)
11-21-2016, 10:16 AM | #3 |
If you used good assembly lube and lubed the cylinders well, you should be able to store it almost indefinitely. Put a few desiccant bags in the bag and suck out as much air as you can with a vacuum cleaner before you seal it up.
11-21-2016, 12:47 PM | #4 |
I had a motor built for a friend for his 64 impala ss by a reputable machine shop.
11 years later I bought the impala with the rebuilt motor still on the engine stand (wrapped in a bag). I pulled the pan just to make sure it looked ok to run, it looked like the day it was put together. 11 years after rebuild, put it in, runs *****en to this day. However, I think I have a head gasket that is marginal so my recommendation is to install a quality set of head gaskets.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
11-21-2016, 04:44 PM | #5 |
I have the cylinder walls coated in an engine oil, normal 10w-30, and I saturated the pistons in it (with rings on) before install. I figured it would be fine but wanted to double check.
11-21-2016, 06:07 PM | #6 |
Fogging oil works wonders. Look into it.
11-22-2016, 12:37 AM | #7 |
That's what I did on advice. I ran some stabilizer through it, shot the carb with fogging oil multiple times start/stop. Pulled the plugs and shot the cylinders, about 3 seconds each I believe per instructions.
B.W. mentioned keeping it dry. All the hoses are disconnected. Anything else recommended? Perhaps another shot of oil in the cylinders every 6 months or so?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-22-2016, 09:17 AM | #8 |
You could put dessicant spark plugs in it to keep the cylinders really dry. They're expensive, like $8-10 each, but that's what aircraft mechanics do when they are storing an engine long-term. Plug-Dri is one brand.
11-22-2016, 01:42 PM | #9 |
I would soak a rag in transmission oil and wipe down every machined surface. WD40, fogging, all of that helps, but a consistent coat of oil on the walls and other surfaces is a good idea.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Tags |
350, assembly, build, motor |
