Grandpa in the rustmobile...
brakes still feel like ther hanging..
I drive down the road after a few miles my brakes (front disc), start squealing etc. I have relatively new brake pads (6 months on a DD). Im going to try to adj. my brake rod, but think its adj. to its max. It has new lines calipers etc.
What can I do, i will check the adj. for sure this evening, Thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#2 | |
Registered Cruiser
Re: brakes still feel like ther hanging..
do you have a combo valve for disc/drum system if you have one for drum/drum it wont release the calipers and cause diiscs to overheat and warp
Had the same problem. Checked and changed everything. It turned out to be the pucks in the caliper need to be removed and cleaned. I ended up flushing the system. I thought it was the rod and portioning valve. But it was a easy fix. Drain and flush system and rebuild calipers.
