12-31-2006, 01:12 AM | #1 |
water trick
if i do the water trick since its cheaper which is lightly pouring water into the carb to clean out the engine, will i notice a difference in performance at all??? or will it not matter??? will there be a decrease in power or an increase and am i crazy to think that the carbon build up would actually increase the comp enough to make a difference???
-steven
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
12-31-2006, 01:16 AM | #2 |
Designated A-hole!
Re: water trick
I personally would try seafoam. You can get it at any parts store and I've heard no complaints about it.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
12-31-2006, 01:20 AM | #3 |
Re: water trick
Krue,
Seafoam? Never heard of this stuff what exactly is it?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
12-31-2006, 01:28 AM | #4 |
Re: water trick
seafoam is a thin liquid almost like paint thinner and it is highly toxic ive used it before to clean out oil passage ways before and it did a great job you can put it in your gas oil and even suck some up into some vaccum lines will smoke like a freight train but will clean the engine to almost perfect
12-31-2006, 01:32 AM | #5 |
Hand Crafted C-10
Re: water trick
Is this the same concept as using Kerosene to quiet noisy lifters? Or using trany fluid to wash out sludge? Wouldn't this flood the bearings down with crud?
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
12-31-2006, 01:44 AM | #6 |
Re: water trick
Seafoam is a mixture of isopropyl alcohol and Naptha (a solvent used in Zippo lighter fluid), it's like WD40 in the fact that it has a million uses, and i always keep a can or ten on hand.
as per the can, it: * Cleans fuel injectors * Cleans carburetor jets * Cleans carbon * Stabilizes fuels * Upper cylinder lube * Removes moisture in fuel * De-icer * Frees sticky lifters * Frees sticky rings * Removes moisture in oil * Cleans P.C.V. systems * Cleans catalytic converter odors * Oxygen sensor safe I use it in all my vehicles (and lawnmower) as a fuel stabilizer, when they will sit for an extended period of time, which means that the whole shebang gets a thourough cleaning when they are driven again. you can buy it at most auto parts stores and gas stations. costs a couple bucks a can.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 12-31-2006 at 01:48 AM. |
12-31-2006, 02:20 AM | #7 |
Re: water trick
I second seafoam. or some kinda of cleaner. in my opinion the only place water has the right to be in a motor is in the water jackets. nowhere near the carbs or inside the cyliders
12-31-2006, 03:57 AM | #8 |
its all about the +6 inches
Re: water trick
water in the carb is fine... use a spray bottle set on stream, jack the idle up to 2000 RPM... your fingers can't pump it fast enough to cause damage. This is an old trick that is still used today at emissions testing places that really works.
12-31-2006, 04:00 AM | #9 |
Location: vacaville ca, because it as far from indy as i can be
Re: water trick
im with the no water crowd on this one, you put a nut hair tomouch wtaer and youll hydro lock your motor and wind up with bent rod or explode a piston.
heard alot of good about seafoam but never used it. |
12-31-2006, 04:11 AM | #10 |
Re: water trick
at 2000 RPM with a squirt bottle.... like a windex bottle.... it is literally imposible to do.
They've only been doing it for 50 years or so. |
12-31-2006, 07:39 AM | #11 |
Re: water trick
I agree with Longhorn on this one. I've been doing this for over 30 years and never had any problems.
1997 GMC Sierra Ext 1965 Mustang |
12-31-2006, 08:44 AM | #12 |
Re: water trick
I have done the water trick and noticed an improvement in how the engine runs. When I pulled the ramshorn manifolds off a couple years ago I noticed what appears to be ash in the exhaust runners on the exhaust valves. There was at least a heaping tablespoon of this stuff in each runner????? What the heck!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. Last edited by Sweet72; 12-31-2006 at 08:45 AM. |
12-31-2006, 08:59 AM | #13 |
laying low
Re: water trick
I believe that would be the remains of burned oil getting past the valve seals and or piston rings.
12-31-2006, 09:05 AM | #14 |
I am a Referee of life.
Re: water trick
I can't see water hurting the engine.It's a small amount.Also water injection has been used for years.It helps control detonation by cooling the incoming airflow.The seafoam is probably better.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
12-31-2006, 10:54 AM | #15 |
Re: water trick
My former employer, the repo guy did the water trick on his 97 dodge ram with 360. Worked like a charm. He reved the engine up, not sure rpm. Had a cup of water that he was pouring down the intake. Seemed to work great, no more missies from the carbon.
12-31-2006, 11:11 AM | #16 |
Re: water trick
I learned the water trick from a vo tech instructor over 20 years ago and have been doing it ever since. Slowly poor it in at a high idle and it will basically high pressure steam clean the combustion chamber. I have used sea foam also and I think it works well also.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
12-31-2006, 11:50 AM | #17 | |
Re: water trick
DMX Last edited by DMX84; 12-31-2006 at 11:52 AM. |
12-31-2006, 11:54 AM | #18 |
Re: water trick
if you don't feel like pouring water in the intake, set the sprayer to mist and mist the water above the carb. it will get sucked into the carb and do the same thing, but it takes longer. works just as well. water in the combustion chambers isn't going to hurt anything. you're not going to hydro lock anything with a spray mist or stream from a spray bottle
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
01-01-2007, 09:33 PM | #19 |
Having issues
Re: water trick
A friend of mine took a garden hose to an old ford I-6 with a brick on the gas pedal runnin WOT. It took 20 minutes at full bore to kill that motor.
01-01-2007, 10:12 PM | #20 |
THE VILLIAGE IDIOT
Re: water trick
well glad im not the only one who has done the water trick..kinda intersting to do to..
honestly honey,,i have no idea how that truck got here. |
01-01-2007, 10:26 PM | #21 |
Re: water trick
01-01-2007, 10:31 PM | #22 |
Re: water trick
Masterbeavis,
That is the best thing I have heard done to a Ford in a long time...... ........perfect end to the piece o' ****!!!! |
01-01-2007, 10:31 PM | #23 | |
Weekend Warrior
Re: water trick
Unfortuantly Ford I6's are hard to kill - they will run knocking forever. Most of the 250's and 292's GM's will do the same. as far as the topic @ hand - I would "mist" the bottle over the carb - it will take longer as stated but you certainly won't Hydro-Lock the motor.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
01-01-2007, 11:53 PM | #24 |
Re: water trick
01-02-2007, 01:10 AM | #25 |
67-72 parts finder
Re: water trick
wow the chevy 250 in my dad's old 81 didn't last me long it didn't even get a chance to knock of course it had a 3 spd on the column and no tach with quiet exhaust and i was young dumb and stupid chunked a rod right through the block but it did leave one nice long black mark before it puked the rod and by the way i actually drove it home about 3 or 4 miles with the rod broke it would still start up and run
1969 chevy shortstep 2wd (under construction) 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
