Old 07-02-2010, 01:05 PM   #1
Tanman
Tanman's Avatar
Rear end from a 66 ford Galaxie.
I have a 57 Chevy 3100 and was wondering if a 66 Galaxie 9" rear end will fit? I don't want to have to modify it due to lack of money. Any info would be greatly appreciated.
Tanman is offline   Reply With Quote
Old 07-02-2010, 01:06 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Rear end from a 66 ford Galaxie.
You will have to modify the spring perches and shock mounts... not sure about width...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-02-2010, 01:13 PM   #3
cdowns
cdowns's Avatar
you will have two different bolt patterns then// measureing width you need to do// with new axels and brake drums you can get the same bolt pattern
Old 07-02-2010, 01:27 PM   #4
Tanman
Tanman's Avatar
Thanks for the fast responses. Im putting a camaro front clip on my truck. Also I want to do a 4 link set up. I have tried to contact the seller to see if he can measure the distance between the drums but no word yet. he only wants $100 for it.
Old 07-03-2010, 12:38 AM   #5
Captainfab
60-66 Nut
You will want to measure WMS to WMS (Wheel Mounting Surface) to get an accurate measurement for comparison purposes. Measuring backing plate to backing plate is not the correct way to measure the width of a differential. Especially when comparing different manufactures of differentials. The reason is due to the fact that there are differences in brake shoe/drum widths.
Even with the Camaro front clip, you will have a 5 x 4.75 bolt pattern up front and likely 5 x 4.5 in the rear with a 9"
Old 07-03-2010, 02:12 AM   #6
Rich 5150 69
Rich 5150 69's Avatar
Some info here..
Ford Rear Dimensions
These measurements are from flange to flange. Subtract 5" for bare housing length.
65-66 Mustang 57.25 inches
67-70 Mustang 59.25 inches
71-73 Mustang 61.25 inches
77-81 Versailles 58.50 inches
74 Maverick 8" 56.50 inches
75 Mustang II 8" 57.00 inches
67-73 Mustang, Torino, Ranchero, Fairlane 9" 59.25 inches to 61.25 inches
57-59 Ranchero and station wagon rears, 57.25 inches
66-77 Bronco 9", 58 inches
77-81 Granada/Versailles, 58 inches
67-71 Comet, Cougar, Mustang, Fairlane, 59.25 inches
71-73 Mustang, 61.25 inches
64 Falcon 58 inches
67 Cougar 60 inches
67 Fairlane 63.50 inches (coil springs)
72 Ford Van 3/4 ton 68 inches
73-86 65.25 inches
57-59 Ranchero and station wagon 57.25 iches (narrowest 9" housing)
66-77 Bronco 58 inches but has 5-on-5 1/2 inch diameter bolt circle
67-73 Torinos, Rancheros, Fairlanes 59.25 inches or 61.25 inches
67-71 Comets, Cougars, Fairlanes 59.25 inches
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 07-03-2010, 04:33 PM   #7
Tanman
Tanman's Avatar
Awesome. Thanks you guys for the info. I picked up a 66 ranchero 9in today.Its in good shape for $150.
