Old 11-15-2012, 04:33 PM   #1
Portmod7
Portmod7's Avatar
Buddy Bucket Console/Center Seat Dimensions
Can any of you buddy bucket owners out there take some measurements for me?
I wanted to see if I could get the dimensions of the "box" (length, width, height) including the dimension from the bottom to the centerline of the hinge. Also, the thickness of the material it is made of.
Also the dimensions of the seat and backrest. Same thing; length, width, and height.
Thanks in advance for any help!
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 11-15-2012, 09:25 PM   #2
rpatowers
Re: Buddy Bucket Console/Center Seat Dimensions
Can somebody help this fellow out??
rpatowers is offline   Reply With Quote
Old 11-16-2012, 12:31 AM   #3
nds1968
nds1968's Avatar
I'll try to get some measurements and pics tomorrow if no one else beats me to it. Nate
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 11-16-2012, 10:30 AM   #4
Portmod7
Portmod7's Avatar
Thanks guys, I appreciate it!
Old 11-16-2012, 08:33 PM   #5
nds1968
nds1968's Avatar
Let me know if this helps, I don't know how to make the dimensions on the photos. 16 gauge .0625 thickness All measurements are from inside of bends. Inside dimension is 12 5/8" wide and 16 5/8" long. The sides and front are 3 5/8" deep and the rear is 7 3/4" deep. The return lip on the sides and front are 7/16" The front corner angles are 15/16" x 15/16" x 3 5/8" high. The rear Z support is 9/16" x 7/8" x 15/16" x 7 3/4" high.
Nate
Old 11-16-2012, 08:35 PM   #6
nds1968
nds1968's Avatar
Hinge width measurements. 1 7/8"--1 3/16"--5 1/4"--1 3/16"--1 7/8"
Nate
Old 11-16-2012, 08:57 PM   #7
nds1968
nds1968's Avatar
The outside diameter of the hinge is 3/8" The center hinge bracket bolted to the seat measures 5 1/4" wide by 4 3/16" from center of hinge with a 1 1/2" return that has the screws.
Nate
Old 11-16-2012, 09:00 PM   #8
nds1968
nds1968's Avatar
Hope this helps and not confuses you If you need additional measurements let me know. Maybe if you can make the photos with a line I can give specific measurements. Nate
Nate
Old 11-16-2012, 09:38 PM   #9
Portmod7
Portmod7's Avatar
That's AWESOME Nate, thanks a ton! Could I ask another favor, and get you to measure the seat and back pads? Then I should have everything I need.
Thanks again!
Old 08-25-2014, 01:17 AM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Did you ever get the remaining dimensions you needed?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-25-2014, 01:44 AM   #11
leddzepp
Moderator
leddzepp's Avatar
14 5/8" wide.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 08-25-2014, 01:49 AM   #12
leddzepp
Moderator
leddzepp's Avatar
17 3/4" long.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 08-25-2014, 01:56 AM   #13
leddzepp
Moderator
leddzepp's Avatar
The top cushion appears to be 14 5/8" square
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 08-27-2014, 09:22 PM   #14
LostMy65
LostMy65's Avatar
Thank you
Old 03-26-2024, 09:54 PM   #15
SOON2BLAZE
SOON2BLAZE's Avatar
Getting ready to take a Slosh Tub buddy bucket console to the upholstery shop. Any chance anyone can post the thickness of the seat bun and armrest portions as my upholster will do the foam as well. Thanks, Chris
SOON2BLAZE is offline   Reply With Quote
