Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-18-2017, 04:08 AM   #1
Northwest Outlaw
Northwest Outlaw's Avatar
Lost brake and blinker
1961 Apache10.
Thought I had everything worked out, but nope. I'm posting this at 1am after wasting an entire evening chasing gremlins only to get right back to where I started, without passenger side brake light or blinker.
Tail lights work fine, both the same brightness.
Weird thing is both blinkers work when the taillights are off, but only driver's side works with the tail lights on. When the taillights are on and I try the passenger blinker, the license plate light pulses.
Any help much appreciated. Thanks
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline   Reply With Quote
Old 05-18-2017, 11:01 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Lost brake and blinker
Check the right light socket for a good ground. With lights off, pull the bulb and check the continuity between the dark green wire and the socket housing for zero ohms with an ohm meter. Then check the brown wire for the same. If resistance is high then you will have to clean the socket mount to frame.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-18-2017, 11:20 AM   #3
Northwest Outlaw
'61 has black and white wires to socket, taillights and brake/signal respectively. I will check the grounds, which are the mounting screws, and make sure the metal to metal contacts are clean.
I might add an additional ground wire from the taillight housing to the frame, that shouldn't cause any issues right?
