Old 11-27-2007, 07:13 PM   #1
lapranch
lapranch's Avatar
tailgate crack
have a crack on top of my jimmy tailgate. I thought it was unique to my truck.but I've now noticed the same crack on many other blazers/jimmys that i've come across.
just wondering if anyone knows what causes this.
lapranch is offline   Reply With Quote
Old 11-27-2007, 07:31 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: tailgate crack
I have the same thing on mine, I am fixing this as we speak. The only thing that I can think of is closing it hard. I would think that would do it. I am putting new rubber on the gate and hope this will help too.
tvblazer78 is offline   Reply With Quote
Old 11-28-2007, 07:01 PM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
Re: tailgate crack
Ditto for mine. Cracks on both sides. I'd have to agree that it's from slamming it shut. I've got a absolutely cherry tailgate (no cracks, no rust at all!)to replace mine though. I'm going to take my time to adjust it and get it to shut without excessive force.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 11-28-2007, 07:27 PM   #4
lapranch
lapranch's Avatar
Re: tailgate crack
thanks for the replys. Other than the crack my tailgate is still pretty cherry.
so I'll probably weld up the crack when I get around to it.
Old 11-28-2007, 10:07 PM   #5
wildmanaaron
Re: tailgate crack
Mine did it too. I agree that it has to be from the top and the pressure that is pushed towards that area. I had my whole tailgate sandblasted to see how rusty it was and I am quite pleased with how it turned out.
wildmanaaron is offline   Reply With Quote
Old 11-29-2007, 01:02 PM   #6
tobiahr
tobiahr's Avatar
Re: tailgate crack
the crack is caused because the tailgate has play in it when closed that the glass does not. years of flexing cracks the sides of the window channel on the tailgate. to see what i'm talking about look at how much movement the tailgate has when latched with the rear glass down and how little it has with the rear glass up. the only good fix i've seen was putting very firm weather strip and adjusting the latches so the tailgate wont move when closed. there is also a spot welded brace inside some newer model tailgates.
tobiahr is offline   Reply With Quote
Old 11-29-2007, 01:59 PM   #7
hiway
Mad Scientist
Re: tailgate crack
Good read. New to the Jimmy and mine has the same crack. 1984 model. Any way to make the window roll up faster? New motor says the previous owner.
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 11-30-2007, 11:08 AM   #8
Zoomad75
K5Camper
Zoomad75's Avatar
Re: tailgate crack
Grease! Take the access panel off and grease the snot out of the tracks/rollers on the regulator. It don't hurt to hit the rest of the moving parts of the regulator with some too.
While your there, check out the condition/shape of your rollers. If the tracks were bone dry, if not rusty chances are your rollers arent round anymore. You can get new rollers from LMC or your local Chevy dealer. Just have them look it up for a 91 Blazer or suburban. Drill out the old rivits, install the new rollers by peening down the ends of the roller shafts to the regulator arms. It's an easy job.
Rob Z.
Old 07-20-2020, 03:59 PM   #9
wazzabie
Re: tailgate crack
has any one welded this and later have the crack reappear?
wazzabie is offline   Reply With Quote
