Old 03-23-2022, 09:20 AM   #1
5567Cruiser
5567Cruiser's Avatar
My 1956 3100 Build
Attached is my build of a 56 truck that I brought back from Arizona in 1976 and now doing a frame off restomod restoration. Chassis is done and now the dirty work starts of prepping body for paint. Engine is a 350, trans Gearstar 700R4 level2, TCI front and rear suspension with 87 Firebird Rear end with disc brakes and Thunderbird Rack and Pinion steering.Name:  IMG_1706.jpg
GARY
67 LWB CST FLEET
56 CHEV 3100
55 CHEV BEL AIR 2DR SEDAN
67 BUICK GS400 CONVERT
5567Cruiser is offline   Reply With Quote
Old 03-23-2022, 10:32 AM   #2
dsraven
Re: My 1956 3100 Build
whats the plan with the truck? grocery getter, weekend driver, show truck?
dsraven is online now   Reply With Quote
Old 03-23-2022, 11:00 AM   #3
5567Cruiser
The Engine has an RV Cam, Edelbrock 600cfm carb, Electronic ignition, aluminum heads and Sanderson headers. The pontiac rearend has a 2.73 ratio.I plan on a nice cruiser to take antwhere with good mileage and reliability and look great from 25 feet and definitely not a trailer queen.
GARY
67 LWB CST FLEET
56 CHEV 3100
Old 03-23-2022, 11:29 AM   #4
6DoF
6DoF's Avatar
6DoF is offline   Reply With Quote
Old 03-23-2022, 11:56 AM   #5
bosco
bosco's Avatar
Drive it and enjoy it...
bosco is offline   Reply With Quote
Old 03-23-2022, 01:30 PM   #6
cameo
Nice Project, very similar components to mine. should be fun
is that a 2.73:1 ratio a typo? I know there is that ratio, I had it in my Blazer, but with the 4spd trans, you may be interested in swpping to a 3:73, otherwise you will be doing 80 mph at 800 rpm. or you could run golfcart wheels and tires, may look good
cameo is offline   Reply With Quote
Old 03-23-2022, 11:45 PM   #7
washington blue
Cameo beat me to it. 2.73 gears will have you unhappy. The timing will not go to full advance, the vacuum advance will suffer. The carb vacuum will suffer. The torque converter will not lock up, and your gas millage will really suffer.
Those engines need about 2200 rpm to be happy.
washington blue is offline   Reply With Quote
Old 03-24-2022, 01:10 AM   #8
dsraven
here is a good rpm calculator, maybe an idea to check it out. if you know the trans you have you can figure out the final drive ratio and the ratios between gears. plug in a few specs and the calculator will finish the last one for you.
http://www.advanced-ev.com/Calculators/TireSize/
here is a tire size comparison calculator that allows you to compare a few tire sizes. it also has tabs for a few other things like finding tire sizes for different wheel sizes but with the same overall height, etc scroll down for those things.
https://tiresize.com/comparison/
gearstar site has the gear ratios for the 700r4 here
https://gearstar.com/overview-700r4-...hicle%20speeds.
2.73 seems like a highway gear more suited for a 3 speed trans. it's your truck so you build it like you want, just info for you. you can always swap the axle ratio later if it turns out that you don't like it
Old 03-24-2022, 11:07 AM   #9
dsraven
ok, found your build thread.4.8 LS with auto OD trans, 3.73 gears in a camaro axle, MII front end, leaf spring rear, C notched frame, tubbed box, lotsa room likely. I guess pick a tire width that you like , a tire height you like, and use the comparo chart to find a common tire size that won't be a special order if you happen to have a flat somewhere away from home.
