02-13-2019, 10:33 PM | #1 |
What Trans Dipstick and Tube?
Guys,
What are you using for the transmission dipstick and tube for a 65 5.3 with a 4l60e? Thanks |
02-14-2019, 08:03 AM | #2 |
Re: What Trans Dipstick and Tube?
I'm planning to use the one I got from the transmission's donor, a 2008 1500 Silverado. I haven't mounted the cab yet though but wasn't anticipating any problems.
02-14-2019, 08:33 AM | #3 |
Yeah I was just wondering what's wrong with the stock one......is it a clearance issue?
02-14-2019, 10:00 AM | #4 |
When I got my motor and trans (2003 Tahoe, 5.3 Flex, 4L60E) the dipstick tube had been broken at the mounting tab that goes under the transmission bolt. I got a new one from a GM dealer and used the original dip stick.
It has cleared the cab and A/C unit on my 85 C10 with no issue.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
02-14-2019, 10:46 PM | #5 |
Thanks guys, I don't have one and was wondering what worked on the 60-66 models.
02-15-2019, 12:55 AM | #6 |
meowMEOWmeowMEOW
I've had the regular truck version and the van version. Same thing just the length difference. The truck version hides away a bit, the van version is easier to check without leaning over all the way, but sticks out over the passenger side a bit.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
02-15-2019, 09:45 PM | #7 |
I used an fbody, it puts the handle tight to the passenger side of the motor.
Can you see the red handle??
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 02-15-2019 at 09:54 PM. |
02-16-2019, 12:04 AM | #8 |
When you do get a dipstick it should read full when the fluid is even with the pan gasket.
