Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-03-2013, 03:30 PM   #1
88fordf150
88fordf150's Avatar
Whole floor or patch panels?
What would be the best route. Replace the whole floor with braces or patch panels? I know I have to replace both rockers, both front door posts, both kick panels and two small cab floor braces. The floor itself is just rusted near the rockers on both sides.
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 03-03-2013, 04:03 PM   #2
jpmanyhearts
frankenstien Fabrications
Re: Whole floor or patch panels?
I would replace the whole floor the patch panels are great if you know how to tig weld if you do then do the patch panels. the problem I have ran into is the metal of the origional floor is thinner and thicker in places so when you try to weld the patch in with a mig your spot weld will pop or explode because your to hot in that area so you turn your welder down then up ect with a tig it doesnt matter how thin or thick it is you control the heat with the petal
frankenstein Fabrications
jpmanyhearts is offline   Reply With Quote
Old 03-03-2013, 04:22 PM   #3
88fordf150
88fordf150's Avatar
I'm working with a mig welder. Leaning toward doing the whole floor as one piece that way I know I have a nice solid floor and I won't have to clean up the underside.
Brad handshoe
Old 03-04-2013, 11:30 PM   #4
Oldironracing
Oldironracing's Avatar
Buy the time you buy all the prices you be better off doing the hole floor. Less work to do the whole floor.
OLDIRONRACING
Oldironracing is offline   Reply With Quote
