Old 02-23-2011, 02:32 PM   #1
DavTay
Transfer case adapter seal replacement help!
I think I have a leaking seal between the transmission and transfer case.
The tranny is a SM465 (I think) (4 speed w/granny gear) and the transfer case is NP205.
I pulled the speedometer gear drive last night to remove a broke cable and oil seeped out. The transfer case oil level was slightly above this.
I have read there are two seals located inside the transfer case, and then I saw reference to an o-ring. Is the o-ring only on automatics? I didn't see it in the parts diagram.
Has anyone seen the oil seal replacement illustrated online? I have seen great write ups on transfer case rebuilding but nothing on replacing the oil seals.
Does anyone have the specks on the oil seal and o-ring.
Thanks.
DavTay is offline   Reply With Quote
Old 02-23-2011, 06:12 PM   #2
csb#356
Re: Transfer case adapter seal replacement help!
There is two o ring seals around the coupler shaft in the adapter housing. I believe these are the ones you are talking about. They were available at a 4x4 shop here in town when i got mine. Try www.drivetrain.com
csb#356 is offline   Reply With Quote
Old 02-23-2011, 10:47 PM   #3
DavTay
I see two seals listed hear #37. I don't see any o-ring's
Old 02-23-2011, 10:58 PM   #4
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
If your truck has the sleeve between the transmission and transfercase (pre-1985) there are two seals. One at both ends of the adapter sleeve.
This is the tcase side.
This is the transmission side. This adapter is actually a TH350/NP205 but still the same seal and sleeve arrangement as a 465/205
DirtyLarry is offline   Reply With Quote
Old 02-24-2011, 12:19 AM   #5
DavTay
That makes sense, pictures sure help.
Old 02-24-2011, 09:50 AM   #6
DavTay
Since the seals go in with outer faces facing inwards are they hard to get into position?. I know this is the best way to install to seal but there isn't must to press on when installing them. How did you install them?
Also, I see some blue material, did you add some RTV to the seals when installing?
Old 02-24-2011, 07:14 PM   #7
DirtyLarry
DirtyLarry's Avatar
I used a big arse socket to tap them in as I didn’t have a seal driver large enough. The correct tool would be a seal driver. The blue stuff is just the paint from the seal casing...not RTV.
Csb above mentioned o-rings and he is correct. There is also an o-ring that goes on the tailshaft of the automatic trans that goes inside the sleeve. It is usually a good idea to smear some gasket material inside the sleeve threads as well. Between these two seals and that o-ring is probably where your leak is. Replace them all at the same time.
Here is a good place to view the gaskets and other goodies. Thanks Billhilly for the link!
http://www.quad4x4.com/New_Process_NP205_Parts.html
Old 02-24-2011, 10:38 PM   #8
csb#356
Oh yeah thanks larry the o rings i was refering to were the ones in the adapter housing,(don't know why i called them o rings) i completely forgot about the ones around the input shaft.
Old 06-14-2017, 08:58 AM   #9
K5islife
Do the seals need to be pressed all the way in ? There is a lip inside the transfer case, does the seal go all the way down or is it flush with the top? I can't tell from the pics but it looks lik the seals were pressed all the way in until you can't go any further.
K5islife is offline   Reply With Quote
