Old 01-13-2010, 07:17 PM   #1
MT71c-10
Too many toys,not enough money
MT71c-10's Avatar
Which is the correct way to install dist. center plate?
It's a chevy 350 HEI distributor.
Which is the correct way to install the dist. center plate?
I have two of these distributors and the both came apart different.
The top set is out of a Mallory dist. in the picture the center plate has rounded edges on the bottom and a "L" stamped into the top.
The bottom set is GM, all numbers are up.
MT71c-10 is offline   Reply With Quote
Old 01-13-2010, 07:37 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Which is the correct way to install dist. center plate?
bottom right
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 01-13-2010, 08:00 PM   #3
68gmsee
Active Member
68gmsee's Avatar
As hottrucks said...
scroll down for good pictures.
http://www.rustpuppy.org/ignition2/Ignition%202b.htm
68gmsee is offline   Reply With Quote
Old 01-14-2010, 01:08 PM   #4
MT71c-10
MT71c-10's Avatar
Thanks guys, I thought the bottom right was right, but I started overthinking things and confused the heck out of myself.
Old 01-14-2010, 03:50 PM   #5
Ticker
Man, if I had a dime for every time I did that...my truck would have paint
Ticker is offline   Reply With Quote
