Alternator wiring help
I cannot figure out how to wire my alternator, it appears it WAS wired with 2 spade connectors ( 1 brown wire going to the fuse block on the firewall and 1 going to the starter) and the post wire wasn't hooked to anything. I'm trying to get the engine bay properly wired back up.
![]() Join Date: Apr 2009
Re: Alternator wiring help
More info needed on your truck.....
What kind of information is helpful? It's an 1984 K10, 350 carb'd.
Is this what you want? |
That's the correct factory wiring? Do you have that in larger format? I can't make that out.
Just right click the pic, save it to you pictures , go to your "My Pictures' folder , then blow it up.
Desert |
