Old 06-20-2018, 03:18 PM   #1
MaximusD
MaximusD's Avatar
Drop Kit...Too Many choices
Hi All, wanting to lower my 70 SWB using a drop kit. I have read until I am blue in the face and probably more confused. I was leaning toward the ECE (great member reviews) 2/4 Premium Kit but wanted to go a bit lower. Both CPP and Western Chassis have a premium kit in the 3/5 range, my concern is issues with possible rubbing, changing the geometry and over all ride. Currently has 15x8 rally wheels and 275 60 15R all the way around. I am not inclined to change the spindles or brakes at this time. Any advice would be greatly appreciated. Thanks
MaximusD is offline   Reply With Quote
Old 06-21-2018, 07:50 AM   #2
Zeroman
Zeroman's Avatar
Re: Drop Kit...Too Many choices
Call ECE. Talk to them, they are very knowledgeable.
They can probably advise you based on your wants.
Their website also has pics of all of their drops for reference.
I bought my drop components from them 18 years ago..still going strong.
I recently did a total frame off resto, and bought my replacement drop shocks from them as well. Using the same springs and rear shock relocation kit.
I do have plans to bag my truck in the future, but for a static drop I think ECE is the way to go.
Zeroman is offline   Reply With Quote
Old 06-21-2018, 02:13 PM   #3
Pro Performance
Pro Performance's Avatar
Yes, there are many options and we put together a few kits to help make it a little easier. Of course, we can adjust and modify as needed.
http://www.azproperformance.com/Stat...its-63-72-C10/
Pro Performance is offline   Reply With Quote
Old 06-21-2018, 05:11 PM   #4
bs46488
The previous owner of my truck lowered my truck with "other" choices and the geometry and ride is all messed up.
I will be fixing the problem with ECE lowering parts. I'm going with drop spindle and 1" drop in the front, drop spring in the rear
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 06-21-2018, 10:00 PM   #5
Mike C
Mike C's Avatar
It's hard to go wrong with ECE. They have been supporting the 67-72 platform for a long time and have always differentiated themselves with better customer service. They may not be the cheapest but they will do you right.
I put my money where my mouth was and went with their disc conversion on my 69 with the 2 1/2" drop spindles. I did DJM flip on the rear only because ECE didn't offer it.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-22-2018, 12:29 PM   #6
68Stepbed
68Stepbed's Avatar
ECE is the only company I recommend for basic drop kits. I've used another brand and was never happy with their product or customer service. Mark or Stan at ECE have always been willing to step up and make things right or go the extra mile to make sure I'm a satisfied customer.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 06-24-2018, 10:24 AM   #7
Spike 72
Spike 72's Avatar
If your only going 2" up front you shouldn't get a bad ride with just 2" springs. If your concerned with ride use drop spindles. Your A-arm ( lower control arm) will be closer to the ground but shouldn't be a problem and should work fine for 15' Wheels. I have done both on mine. i think if i was you i would just do a 2" drop spring. I have used CPP springs and spindles. I will try ECE or some other well known company next time. As far as having a good ride out back with a 4" drop....good luck! Im still battling that one. If you go with ECE for rear springs let me know how you like them.
Spike 72 is offline   Reply With Quote
Old 06-25-2018, 02:53 PM   #8
MaximusD
MaximusD's Avatar
Thanks guys, looks like you've all verified what I've heard, use ECE. I'll be placing a call soon!
