Lowering a 3/4 Suburban
How much of a drop do I need to to make mine (red/tan), look like the blue one?
![]() 1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
Re: Lowering a 3/4 Suburban
I’d also be interested in knowing. I’d say at least a 5/7. That thing is pretty dang low.
Also if you go to a 5-7 drop. Check if you have a 14 bolt FF or SF rear end. The smaller semi floater still is 8 lugs, but also give needed room for a deeper drop. Before you cut into the body.
