01-06-2017, 08:38 PM | #1 |
Suburban body interchangability
I have a 73 burb that has pretty bad roof rot. Found an 84 body with very minimal rust for free locally. From my untrained eye, the bodies look the same, i plan on putting my doors into this body. Will everything be good, or is this deal too good to be true?
01-06-2017, 11:47 PM | #2 |
Re: Suburban body interchangability
Yes, the bodies are the same except the front end sheet metal is different.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
01-06-2017, 11:48 PM | #3 |
They are both the square body design, only real difference being the front clip. Frame mounts should all be the same, even up to 1991
01-07-2017, 01:10 AM | #4 |
freaking awesome. thanks guys
