05-12-2017, 05:01 PM | #1 |
thought I would share this
For you guys hooking up a hei and a aftermarket tach if you search out square bodys in the jy some have this hei hot wire connector that has the tach side of the plug all in one.
I've used these in the trucks I put together for myself just for a clean look and a secure connection on both terminals. I have seen cheap terminals come loose on hei and cause problems. It won't happen with this. These do have two wires coming off the tach side but one is easily snipped off close too the terminal with no problems, Solder it all in and run.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
05-12-2017, 11:19 PM | #2 |
Msgt USAF Ret
Re: thought I would share this
Great tip, Thanks. VV
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-13-2017, 10:37 AM | #3 |
05-15-2017, 09:44 AM | #4 |
Thanks for the tip. I'm going to be on the lookout for one on my next salvage yard trip.
