05-08-2017, 04:14 PM | #1 |
65 c10 Panckaed Crossmember question
So im about to pancake my crossmember 1.5 inches and ive read that you want to move the whole crossmember forward an inch to center the wheels in the wheel wells. But asi was looking at mine, it appears that if i move it forward, it will hit the steering linkage. Am i missing something?
05-08-2017, 05:48 PM | #2 | |
Re: 65 c10 Panckaed Crossmember question
05-08-2017, 06:17 PM | #3 |
I must have misread it then. So you just pancake and rebolt it in its original spot?
05-08-2017, 09:08 PM | #4 |
Diggin The SquareLife
Yes
05-08-2017, 10:14 PM | #5 |
Thank you
05-11-2017, 09:23 AM | #6 |
Porterbuilt makes "forward arms" to center the wheels and change the geometry.
http://67-72chevytrucks.com/vboard/s...d.php?t=742865 66 SWB, C4 Dropmember timmytimm3 on IG "If you don't have time to do it right the first time, when will you?" -Dad |
05-12-2017, 01:53 AM | #7 |
Yeah using forward control arms will be a lot easier then moving the crossmember.
