O2 sensor on headers
I just installed long tube headers on my 1991 suburban 350 2wd, I was wondering what to do with the o2 sensor? Ive heard use the stock single wire one in the header collector or put it on tube #4 or #8. I've heard use a 3 wire sensor. Any help with this problem? Thanks!
Posted via Mobile Device |
I know the pieces fit
Re: O2 sensor on headers
I didn't know those needed to be tricked. You can't just add a bung to one collector and reuse the original o2 sensor?
That's what I'm hoping to do, but the research said its ideal to go with a 3wire o2 sensor. Idk that's why I'm trying to get any input I can. Thanks for the response!
Just weld the nut all the way down by where the collector bolts to the exhaust and extend the wire [wrap it with something heat resistant too!] I did it with a new o2 and it works fine!
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
#5 | |
No need for a three wire heated O2 sensor unless your vehicle originally came with one. -cal30sniper
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress 73 Formula - 400/Doug Nash 4+1, resto on hold 86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale 01 Ram 2500 - 5.9L Magnum, daily driver 91 BMW 325i - Chumpcar series racecar |
I put an H pipe in the exhaust just past the collectors and install the 02 there if possible. it draws off both banks then and monitors the entire engine.
if you can't do this then just put a bung in the collector and go on. The single wire unit is a good unit for the app they're used in. |
The problem with the H-pipe O2 sensor is that your readings are very far removed from what the engine is actually experiencing. There's a time delay for the exhaust to get there, especially considering that you're going to have mixing and stagnation inside the crossover. Heat within the crossover is also much less than the collectors, which could screw up the readings (both actual composition of the exhaust, and what the sensor actually reads).
I would not advise putting the sensor in the crossover. Not saying it won't work, but it's definitely not ideal. The factory sensor only reads one bank, because it is placed as close as possible to the cylinder exit that can still get an averaged bank reading. That is for reasons of both temperature and response time.
#8 | |
