![]() Join Date: Feb 2007
frame boxing
Hi gang,
Is there any issue with recessing the added plate when boxing a frame? I'm considering insetting the plate an inch or so for clearance of brake and fuel lines and wiring. I'm planning to use 3/16" with 2" dimple dies. Thanks, steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
Re: frame boxing
Wouldn't think so, that's exactly how I would it.
Re: frame boxing
I agree, it also gives you room for a nice fillet weld.
![]() ![]() Join Date: May 2015
Re: frame boxing
wouldn't think so....and itll give a nice little ledge to weld on...
![]() Join Date: Mar 2003
Re: frame boxing
Lot of work boxing in a frame correctly. Keeping it straight and putting in a lot of bolt sleeves.
#6 | |
Re: frame boxing
Since I'm adding a flatbed, I was recently told boxing the rear end isn't necessary but I question that. What are your thoughts?
![]() Join Date: Jun 2011
Re: frame boxing
I don't think it is necessary to use 3/16, that adds a lot of weight.
Tom in Iowa 68 L88 C10 68 4x4 C10 soon |
Re: frame boxing
Ok, I could do 1/8th inch and larger dimple dies?
Re: frame boxing
Even 1/8 is overkill. I'd consider 14 ga.
Re: frame boxing
[Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's ]
im assuming this ^^^^is why your wanting to box the frame?
Re: frame boxing
No, I'm starting a late '80's square body 4 door diesel project that will be getting boxed and a 12V.
