Old 05-26-2013, 09:43 AM   #1
wahl4m
83 ign switch bad ?
my 83 c-30 ign. switch is sticking/hard to start /unless you shake key or jiggle it/or lift up and turn ! what part is actually bad ? key assembly or what ?how is lock cylinder removed from column ?{non tilt-automatic} thanks
wahl4m is offline   Reply With Quote
Old 05-27-2013, 06:39 AM   #2
gmcnorton
gmcnorton's Avatar
Re: 83 ign switch bad ?
sounds like your key itself is worn . does your key look worn down ? if not the lock cylinder is removed by a torx screw under the lock plate in column. you need to pull the wheel, use puller (pusher) to hold the lock plate down to removed snap ring. remove screw & remove key cylinder. good luck hope it helps.
70 GMC SHORT STEP , 71 BLAZER ,72 JIMMY,72 BLAZER, JUST NEED THAT SUBURBAN NOW......WANTING MORE
gmcnorton is offline   Reply With Quote
Old 05-27-2013, 12:55 PM   #3
wahl4m
thanks for the reply- the key is good -not worn-even had new one made /same thing !gues i will buy a new key assembly and try that ! thanks mike
