11-18-2017, 12:23 PM | #1 |
Throttle linkage hookup on Fitech ??
Looking for any info (pic please) on the hookup of Acc linkage on a Fitech setup for 67 C10 with 383 engine. I have a bracket from Jegs for the 700R4 TV cable but the bracket has a square hole for the acc cable and my acc linkage is a straight rod type.
11-18-2017, 12:27 PM | #2 |
Re: Throttle linkage hookup on Fitech ??
Looks nice!! I'm going to assume, you are going to have to convert your rod style linkage to a cable style, to make this work. Check with Lokar. I think they have what you may need.
11-18-2017, 07:29 PM | #3 |
Ok all good on this one I have done this also new GM crate engine / 200 4r trans / installed fitech efi
This is what you need ( FAST EZ EFI Mount Kit part # 304-147 ) ,I ordered from Summit , if you look at the reveiws for this kit you will see others used for fitech install. a little on the high $ end as far as price but everything you need with O problems on install . I also have Rod style gas linkage / 200 4R and 700 R4 use same Detent cable and I will add cable is just where it should be for smooth operation . |
11-18-2017, 07:37 PM | #4 |
I dont know what kit you have, but the square hole is for your Detent cable it snaps in the square you want to install that squre bracket so the cable is level all the way through to your hook up on the fitech, it is not your gas/fuel linkage ,
11-19-2017, 09:03 PM | #5 | |
11-19-2017, 09:33 PM | #6 |
What did you use to paint your engine with?
11-19-2017, 09:43 PM | #7 |
11-19-2017, 09:46 PM | #8 |
Thanks. It looks nice.
11-19-2017, 11:52 PM | #9 |
Here’s what I did. Rebuilt new rod with parts from summit
Posted via Mobile Device Last edited by hotrod1967; 11-20-2017 at 12:00 AM. |
11-20-2017, 12:03 AM | #10 |
11-20-2017, 01:41 AM | #11 |
Active Member
Can't you just loosen the fuel pressure gauge fittings and point it up a little? Although converting to a cable throttle is safer.
David Larsen 1970 Chevrolet C-10 |
11-20-2017, 09:23 PM | #12 |
Got the Acc linkage/TV cable adapter plate and TV cable bracket made today. Had to modify everything. Jegs #157301 &157310
11-21-2017, 01:04 PM | #13 |
Do Holley and Edlebrock carbs have the same throttle lever? FiTceh throttle levers have the same geometry as Holley. The Jegs 157301 is for Eddy carbs. I think you should have used a 157300 for 4150/4160 Holleys. Not sure you are going to get the correct geometry from the 157301.
I'm running the FiTech and could never get the linkage style pedal to open the throttle 100%. Installed the bowtie EZ-TV kit & a 72 cable style pedal. Problem solved.
Made in America by Americans |
11-21-2017, 07:37 PM | #14 | |
Thanks. Darren |
11-21-2017, 07:54 PM | #15 |
Yes I was able to keep the rod style linkage . looks good just make sure you pull (adjust) that detent cable all the way
11-22-2017, 01:51 AM | #16 | |
Bowtie Overdrive's TV Made Ez system - TVEZ4100 $149.95
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
