06-30-2009, 12:40 AM | #1 |
How to mount dash speaker
I'm looking for knowledge and possibly some pictures of the original mount dash speaker. I'm looking to installing a radio in my 67 project but I don't want a bunch of speakers. If anyone know what is required or possibly has the mounting brackets, etc. Please let me know.
Thanks, Nick |
06-30-2009, 01:43 AM | #2 |
The Red Menace
Re: How to mount dash speaker
There is a small bracket bolted to the inside of the dash. The speaker slides into this. The speaker just presses against the underside of the dash. There is also a flat piece that connects the radio to the speaker bracket and a bolt or three to hold the whole thing together. I wish I had some installed photos, but it's pretty tight in there and and would be hard to get good shots. If the photo and my description aren't enough, let me know and I'll try and make it clearer.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
06-30-2009, 01:50 AM | #3 |
The Red Menace
After I responded, I found this thread a little farther down. It contains a good photo of the speaker bracket.
http://67-72chevytrucks.com/vboard/s...d.php?t=350692 PM me, I have a spare one of those speaker brackets you can have if you need it.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." Last edited by red71c10; 06-30-2009 at 01:51 AM. Reason: Generousity |
06-30-2009, 02:02 AM | #4 |
69 Fleetside
I made a wood bracket and mounted it to the stock grill via some allthread, washers, and nuts...came out nice and sounds great..
06-30-2009, 07:46 AM | #5 |
Thanks Red, I sent you a PM.
06-30-2009, 09:07 AM | #6 |
Also, check out Custom Auto Sound. They make a really good replacement speaker that is a "dual voice coil" 4 x 6 that fits right up there and sounds about a thousand times better than the original paper element speaker.
06-30-2009, 09:13 AM | #7 |
http://www.turnswitch.com/speakers.htm
ELECTRO-TECH The above site also sells a factory direct dual cone 8-10 ohms speaker. Keep in mind most aftermarket speakers are 4-6 ohms which could possibly damage your radio. Good Luck with your project.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
07-01-2009, 07:01 PM | #8 | |
The Red Menace
07-10-2009, 07:59 PM | #9 |
Thanks Dan, I got it today. Does any thing screw through the firewall?
07-10-2009, 11:04 PM | #10 |
The Red Menace
Borrowed this pic from the other radio thread. This little bracket attaches to the inside of the dash/firewall, but nothing actually goes through the firewall. The long speaker bracket slides into the little one and is held in place with a bolt.
07-11-2009, 06:16 AM | #11 |
Ok, I'll check it out see if I can figure it out. Thanks.
07-14-2009, 04:01 AM | #12 |
Ok, thanks everyone for your help. I've got the bracket installed but no speaker yet. I ordered it today from the link above. I made some notes in my pictures so hopefully they'll help the next guy trying to do the same install.
07-14-2009, 07:46 PM | #13 |
The Red Menace
You got it! Now all you need is one to go from the radio to the firewall bracket. You can see the one I'm talking about in that borrowed photo from my earlier post. It should run from the back of the radio into the side of the firewall bracket. If you don't have the real thing, metal plumber's tape is always a good substitute.
