02-07-2016, 01:29 AM | #1 |
Wheel hop
So i have a 68 short-bed step-side i put a 9 inch rear 500hp 402 5 speed tremec .Needless to say no traction and horrible wheel hop .It has the leaf spring set up now just looking for some tips to get traction on a budget .Traction bars cal tracs ?Or bight the bullet and do a four link ? Lowered 4 and 4 now.Thanks Oz
02-07-2016, 07:46 AM | #2 |
Re: Wheel hop
Sand.
02-07-2016, 08:57 AM | #3 |
Re: Wheel hop
I would try the caltracs first, and transfer any weight that you can to the rear.
Beyond that, 4 link, coil overs, and sticky tires.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
02-07-2016, 09:22 AM | #4 |
Re: Wheel hop
That's one good thing about the coil rear trucks. Traction bars are your quick fix. Is the axle over the springs for your 4" drop? That helps wrap compared to axle under springs. McGauphy's offers a reasonable solution
http://www.googleadservices.com/page...Fseid%3Dsrese1 I used this design made by someone else in the '80s on a 500 hp '71 Blazer with 4" blocks and 37" Swampers (TH350). They took the wrap out. But that truck got run hard in the mud, not on dry pavement and that was an automatic. Still, that's what they'll do with blocks and tall tires.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-07-2016 at 04:36 PM. |
02-07-2016, 03:41 PM | #5 |
Re: Wheel hop
I find traction bars work reasonably well but most people don't set them up properly and give them a bad rap . its been a while but the rubber snubber is supposed to be something like 3/4 inch and closer from the spring in gear . I have seen 2 to 4 inches on cars almost to the point where they should dig the pavement at a big enough pot hole . they need to be close enough to the spring to pull the rear end back down to the pavement when the spring starts to wrap up this eliminating the hop . I have used plate steel to shim them up not at the snuber but at the part where the ubolt bolts them to the spring . I have also eliminated the ubolt and used a plate on top of the spring and grade 8 bolts because the ubolts can break especially on anything more than stock horsepower levels . good luck on whatever you try
02-07-2016, 11:55 PM | #6 | |
Re: Wheel hop
02-07-2016, 11:56 PM | #7 |
Re: Wheel hop
02-07-2016, 11:56 PM | #8 |
Re: Wheel hop
I used cal tracks they worked great
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-07-2016, 11:58 PM | #9 | |
Re: Wheel hop
02-08-2016, 12:00 AM | #10 |
Re: Wheel hop
02-08-2016, 12:04 AM | #11 | |
Re: Wheel hop
