Tie Rod Adjustment Sleeves Loose
Hey guys. You ever heard of a loose tie rod adjustment sleeve being loose causing a severe steering wobble?
98 C1500 suburban 5.7L Vortec. |
Re: Tie Rod Adjustment Sleeves Loose
I had one come loose that caused a clunk when turning, but I would say that it could cause a little wobble. I'd check your wheel balance and alignment too. Once you replace the sleeve you'll need an alignment anyway.
Mike |
