11-14-2020, 08:42 PM | #1 |
EZ Wiring Harness Help Needed
I have an EZ Wiring harness I'm installing in my 72 Blazer. I've installed a 5.7 Vortec complete with the serpentine system from a 98 Silverado, which means I'm running a 100 amp alternator.
The question I have is about two red wires, one marked Solenoid Power and the other marked Alt Power. The Solenoid Power wire is a heavier gauge, and I believe it draws power from the battery terminal on the solenoid to feed the fuse panel. I believe the other one is the charging wire. The wiring diagram for a 72 shows power coming from the alternator being split, with one wire going to the fuse block and the other going to the battery. My concern is that the alternator wire in the kit is not heavy enough for a 100 amp alternator. So should I just run a bypass wire from the alternator to the battery, or is there a better way to wire it? And I know some of you are saying, "Why didn't you just buy AAW?" The cost was a fraction of the price of the AAW kit, and after all the money I've spent trying to get this thing back on the road... it just seemed like a lot. Anyway, thanks for any help you can give me.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-14-2020, 09:45 PM | #2 |
Re: EZ Wiring Harness Help Needed
Subscribed as I ready to install the same engine into my 72. Post some pictures of the install when you can.
Thanks!
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
11-15-2020, 02:58 AM | #3 |
Are you making it carb intake or efi ?
Cs130 alt will need a 85 watt resistor it is not ecm controled Here is two pigtails that will work as well as a thread on adapting a cs130 https://www.napaonline.com/en/p/ECHEC82 https://www.painlessperformance.com/wc/30705 http://67-72chevytrucks.com/vboard/s...=720105⁹ |
11-15-2020, 09:40 AM | #4 | |
We once had a strippo Cavalier training car. It had a 105 amp alternator with only a 10 gauge ouput wire. It was really easy, with a battery tester, to show students a couple volts of drop on that wire when the alternator was maxed out.
11-15-2020, 02:01 PM | #5 |
It's a Quadrajet carb (electric choke) and HEI distributor. I'm thinking of running the Solenoid Power wire to the battery via fusible link, and adding another wire running from the alternator to the battery with another fusible link. I'm also replacing the amperage gauge with a voltage gauge.
Although I don't plan on running any heavy loads at the present, I prefer to err on the side of caution.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson Last edited by truckster; 11-15-2020 at 02:18 PM. |
11-15-2020, 04:48 PM | #6 |
How about running the alternator power wire to alternator (B post I think) and solenoid power wire to the solenoid. The EZ wire instructions tell you to run a bypass wire if using an alternator rated above 80 amps. The kit includes a black wire marked bypass. There is a diagram in the instructions.
11-15-2020, 05:39 PM | #7 |
I know it's not the same but on my Painless kit the alternator charge wire (I think 6 gauge) is coming off the center post of the solenoid that the battery cable attaches to. As is the 12 volt positive wire that goes to the fuse block to supply power to the truck. That wire has a maxi fuse in-line. The only other wire going to the solenoid is the purple? start wire and it's attached to one of the small studs on the solenoid.
I don't know much about fusible links but the down side is that if they go they aren't easy to replace unlike a fuse. |
11-15-2020, 05:52 PM | #8 | |
11-17-2020, 02:16 PM | #9 |
Could you be more specific as to the guages of the wires in question? I am not familiar with your specific harness.
Although it won't directly apply to your project here is a link to how I wired a late model alternator in my Burban. I tried to post all the links that helped me. Scroll to post 467. https://67-72chevytrucks.com/vboard/...698377&page=19
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-17-2020, 02:18 PM | #10 |
The Solenoid Power wire is 12 gauge. The Alt Power is 14 gauge.
Thanks for the link. I had a hard time making it past the picture of the GTO Judge...
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson Last edited by truckster; 11-17-2020 at 02:24 PM. |
11-17-2020, 02:57 PM | #11 |
That car is perfect down to the GM seat belt instructions on the visors. That Judge color combination is really rare and beautiful too.
06-13-2023, 05:02 PM | #12 |
So where does it go?? Damnit I hate when a thread drops at the answer nothing pisses me off more than the answer you seek is the inly thing not said after reading the whole damn thing.
06-13-2023, 05:47 PM | #13 |
What exactly are you looking for? Maybe we can help.
