11-08-2018, 02:36 PM | #1 |
Fuse Block
Hello,
I'm planning on re-wiring my 1954 Chev 3100 truck, and researching the fuse panel options. Currently the light switch has a main power lead, then the switch sends out the individual accessories non fused - or 1 fuse in the switch housing. I found this fuse panel and would like to use it. I think it would work well for all accessories that have an individual power feed. My question is: Would it be ok to provide the main light switch power from one of the fuses from the powered fuse panel, then route the output for each lighting circuit from the light switch through a non powered fuse block? Thanks |
