Old 09-01-2019, 07:41 PM   #1
portworks
Need help identifying serpentine setup.
Not the original engine, looking for correct bracket to add air conditioning compressor.
portworks is offline   Reply With Quote
Old 09-01-2019, 08:14 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Need help identifying serpentine setup.
Bracket is already there, you have a bypass pulley to the left of the tensioner
1988-`1995 brackets
Old 09-02-2019, 11:41 AM   #3
Pontiac1976
Pontiac1976's Avatar
That correct started in 1988
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-02-2019, 02:14 PM   #4
95 S_Trucker
95 S_Trucker's Avatar
Those are 88-89 brackets. 88-89 were made out of stamped steel. 90-95 are cast aluminum.
95 S_Trucker is offline   Reply With Quote
Old 09-02-2019, 02:53 PM   #5
Warrens69GMC
Originally Posted by 95 S_Trucker View Post
Those are 88-98 brackets. 88-89 were made out of stamped steel. 90-95 are cast aluminum.
1996-1999 put the compressor on the driver side top, part number 12554522
Old 09-02-2019, 04:20 PM   #6
95 S_Trucker
I had a typo. It’s fixed. It should have said 88-89.
Old 09-11-2019, 07:21 PM   #7
portworks
Thanks for all the replies. With the compressor moved to the passenger side, what condenser and manifold hose set should I use?
Old 09-12-2019, 05:53 PM   #8
SCOTI
SCOTI's Avatar
88-91 sbc Burb should work fine.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-19-2019, 08:20 PM   #9
portworks
Thanks everyone.
