Old 04-03-2003, 02:10 PM   #1
Joe67
67 is sold
Post 67 C10 SWB 5 lug/bolt conversion
I have searched the board and found many unanswered threads.
I have a 67 2wd SWB C10 pickup and want to swap the 6 bolt setup for a 5 bolt so I can run some 15x8 Chevy Rallys I have and improve my wheel selection down the road.
What is required to do this? Swapping parts from a 71-72 1/2 ton truck or buy a kit?
Thanks,
Joe
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 04-03-2003, 04:41 PM   #2
John Fabris
TOTY 2006
John Fabris's Avatar
I think easiest is to find a 71-72 truck, and swap spindle outward including out tie rod, and for rear, just swap entire rear end.
I got my front end from a 1975 truck, and used a ford 9inch rear from a lincoln (rear disc with 5 on 5 lug pattern).
I also added a one ton sway bar from a 1976 truck, and used a 6inch/4inch drop kit from Early Classic that included a new adjustable panhard bar and mounts. So there are several things you can do. Cheapest is to find the parts from a junkyard truck.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 04-04-2003, 10:09 AM   #3
Joe67
67 is sold
Thanks John.
That seems like the best/cheapest way to convert to 5 lug in general.
What about being able to run the passenger car Chevy Rallys that I have? I'd rather buy the right size parts then do the swap and install an adapter kit.
Old 04-04-2003, 10:30 AM   #4
Randy70C-10
Randy70C-10's Avatar
Not sure if there is any way to use those, but you can buy Corvette ralleys that fit trucks. I can't remember who sells them, but they are on the internet somewhere.
Randy70C-10 is offline   Reply With Quote
Old 04-04-2003, 11:03 AM   #5
Joe67
67 is sold
I have seen those wheels.
Trouble is, I have a mint set I was hoping to use on the truck.
Old 04-04-2003, 12:02 PM   #6
kaycee
kaycee's Avatar
Different
Don't forget the car wheels were mostly 4 3/4" bolt pattern as the truck is 5".Just thought I would remind you I will leave now
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 04-04-2003, 12:04 PM   #7
andyr354
Measure the pattern on the wheels you have. There are two different patterns for cars. 5 on 5 and 5 on 4.75
1970 C10: 2WD, LWB, 350, 350 auto, Headers, Duals, Edelbrock 1406 with 2101 intake, and optional rust.
andyr354 is offline   Reply With Quote
Old 04-04-2003, 12:21 PM   #8
Joe67
67 is sold
I'll measure the wheels this weekend to be sure.
Thanks.
