Rear Anti-Roll Bar Setups
I'm looking for some pics of ARB setups on trailing arm suspensions. I'm running low 11's with 1.5x 60ft's and my launch is pretty twisted even with a 10 point 'cage. Looking at installing an ARB to level my launch. Any particular brands to look at? Thanks.
Re: Rear Anti-Roll Bar Setups
When I had factory truck arms, I made one with:
1 3/4" DOM tubing for the bar 1 3/4" sway bar bushings for an RV 3/16" plate steel as the leverage arms 1/2" rod ends with 3/4" tubing for the links to the frame It made a huge difference and was cheap.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
i dont have one because mine is a full Drag truck. that bed floor is super heavy. i have seen anti roll bars done several ways. upside down in cars with stock floors, etc.
It's Better With Nitro
I did a through-frame tube crossmember that houses a splined torsion bar for the rear roll/sway bar on my truck. I used some leftover sprint car torsion bar parts since I don't plan to drag race my truck very often. For a drag race truck, I would mount the torsion bar closer to the rearend housing, go with a larger diameter bar, and shorter arms.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 10-12-2017 at 11:09 AM. |
