found this 72 today
I ran across this truck today. The guy is asking 2000.00 for it and says it runs good but the shifter is broken off. What do yall think and is the shifter easy to fix? Truck is really pretty rough.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club Last edited by Jwill41; 09-03-2002 at 03:18 PM. |
2
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
3
4
5
6
7
8
Pretty clean looking 4x4 for that price. I'd be concerned about the shifter, though. How the He!! do you do that?! Hopefully no internal trans damage, but...
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Price doesn't seem to far off of the mark to me. I believe that those shifter arms are fairly simple to replace. Push down on the little dome and turn counterclockwise. It should then come out.
Oops, I went back and looked again. You already did that ![]()
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
![]() Join Date: Feb 2000
Price doesn't sound too bad. Looks like pretty tight clearance for the front tires near the rear of the fender. I have no idea on the shifter, hopefully that piece isn't jammed in there. Wonder how it happened.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
I would pay 2k for it (if I had the money lol)
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Clearance is tight on the front. Both fenders look like they have been mangled by the tires. The front bottom lip has been cut away on both sides also. Maybe that was because of rust problems.
Giddy up giddy up...
Gimme the tires! What are those, 35's? Not a bad truck for 2 grand but talk him down to $1500 and you'd have the deal of the day.
72 with 69 grille and custom 73-87 stepside. BIG BLOCK 409, SM465, NP205, 3/4 axles slung under a 5" lift, 3"bodylift, 112" frame, and 35inch Pro Comp X-terrains... "BUILT NOT BOUGHT" Here's the site... |
#15 |
You didn't say rough did you!?!?! That truck is purdy. Hell with the tires hittin the fenders. Let it go for now, i think it looks tuff. Well from what i can see, it has a small block and is 3/4 ton. Any more info??? Oh yeah, the shifter should come out. if not at first, you might have to use some sort of redneck inginuity.
Brandon |
#16 | |
Bloo
i dont really knwo HOW it happens but i think that has happened to my 4x4 too.. the shifter on it has been broke off and another welded onto the ball that sits in the top of the tranny.. it doesnt have the down-over-down shifter of a 67-72, it has a over-down shifter like a 88-?
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
#17 |
not sure about 2K...but then again, you don't get much 4WD, for that price.
If the engine IS sound, and everything works, w/o extensive cobbling, its maybe reasonable. The rockers are gone. Up here that means the floors are shot, too. May not be the case, in Texas, tho. Id pull the shifter hump, and take the top of the tranny off. SHould be able to get the shifter stub out that way, and check to see if the inside of the tranny is fragged, as well... Im not high on that rear axle, either (strong, but not too common, anymore -- read: parts availability), but then a 14 bolt FF is a pretty easy swap, IMO. Be nice if the AC was still there... just some things I notice/ my $0.02 -M |
#18 |
I have the same 4-speed in mine and the same thing happened to my stick. They are sort of weak around the base after 30 years of hard shifting.
A few tips: Pop those two spring pins out that hold the pivot ball. It makes it alot easyer. Make sure the tranny is in neutural (use the e-brake) when you pull the old stick out. Its a little tricky putting it in neutral with no stick. Have someone rock the truck and use a lot of pressure and a really big screwdriver I ordered a new stick for 45 dollars from some place in Utah and had to bend it myself. But UPS trucks have the same tranny so it shouldn't be that hard to find a replacement stick you don't have to bend. Because it was very hard to bend without tools. Good thing I eat my wheaties...Pete
1968 Chevy - 3/4 Ton - 4X4 - Longbed - 383ci - TH350 - NP205 Building the motor, painting the engine bay, rewireing everything... (775)-527-1199 / ryanspeterson@msn.com |
