Old 03-08-2009, 05:02 PM   #1
mothertrucker424
mothertrucker424's Avatar
dana 44 8 lug upgrade
i have two dana 44 front axles
-6 lug disc brakes
-8 lug drum brakes
i would like to make a 8 lug with disc brakes what is required?
can i do it with only these axles
i have searched the junkyards for a 8 lug d44 w/discs for a few months and can't find one
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 03-08-2009, 07:28 PM   #2
duallyjams
duallyjams's Avatar
Re: dana 44 8 lug upgrade
You can convert the 6 lug dics to a 8 lug dics with pearts off of a 10 bolt 8 lug.The drum d44 is a open or closed knuckle.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-08-2009, 07:57 PM   #3
mothertrucker424
both axles are open knuckle
and i can't find any 8 lug front axles we are picked dry
Old 03-08-2009, 09:42 PM   #4
OldCreek
OldCreek's Avatar
You need:
3/4 ton spindle
3/4 backing plate/disc caliper mount.
3/4 hub/discs
3/4 lockouts
Use your 1/2 ton calipers (and pads I believe.)
I think you can use 1/2 spindle lock/washers.
I don't know if the 3/4 ton drum spindles are the same or the hub for that matter. You'll still need the backing plate...it is different from the 1/2 ton. And, you'll need the caliper from the 1/2 ton.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-09-2009, 08:52 PM   #5
mothertrucker424
will anything from drum brake axle work?
