Old 10-24-2009, 04:35 PM   #1
1979blkchevy
1979blkchevy's Avatar
Drive shaft please help
where can i find a longer drive shaft or a nice well built drive shaft for mudding and ect I bought a truck a while back and it had a lift on it and the guys didnt extend the drive shaft to even everything up! Any advice on where to get one and what kind i should get will help out alot thanks in advance
1979blkchevy is offline   Reply With Quote
Old 10-24-2009, 04:57 PM   #2
Scootin 81 C20
3/4 Ton Rodder
Scootin 81 C20's Avatar
Re: Drive shaft please help
1979blkchevy, try this site. I think they can get you what you're looking for.
http://www.4xshaft.com/index.html
Benjamin.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD
1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy.
Scootin 81 C20 is offline   Reply With Quote
Old 10-24-2009, 05:01 PM   #3
1979blkchevy
Benjamin.
thanks for the fast response I appreciate it
Old 10-24-2009, 05:06 PM   #4
Scootin 81 C20
3/4 Ton Rodder
No problem. I've heard about them on PowerblockTV. I know Trucks used them and I think Xtreme 4x4 did also. I may use them to replace my 2 part driveshaft on my '81 3/4 ton 2wd with a 1 piece to eliminate a vibration from the carrier barring.
Old 10-24-2009, 05:25 PM   #5
LONGHAIR
The vibration is not caused by the the carrier bearing, so you must have either a slight bend or other imbalance in one of the shafts you already have. A one-piece driveshaft that long will be pretty expensive. The diameter of the tubing gets much larger when they need to be that long. It would probably save you quite a bit to have yours checked/balanced.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-24-2009, 05:38 PM   #6
Scootin 81 C20
3/4 Ton Rodder
If thats the case, would a 1 piece shaft out of a Heavy Half or Big 10 style 1/2 ton truck fit my 3/4 ton?
Old 10-24-2009, 11:05 PM   #7
sierra4x4
sierra4x4's Avatar
If your truck has the 14 bolt full floating axle then yes you can use a driveshaft from a 73-81 1/2 ton as long as the truck has the same trans as yours does. All that you will need is a trick U-joint so it will fit your yoke. The semi floating 14 bolt uses a shorter driveshaft.
sierra4x4 is offline   Reply With Quote
Old 10-24-2009, 11:15 PM   #8
Scootin 81 C20
3/4 Ton Rodder
I'm going to be changing the fluid in my rear axle, how can I tell if it's indeed a FF?
BTW, sorry for stealing your thread 1979blkchevy.
Old 10-24-2009, 11:25 PM   #9
3r!c84
Badass
3r!c84's Avatar
if you can do this
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-24-2009, 11:34 PM   #10
Scootin 81 C20
3/4 Ton Rodder
Ah. "I see." said the blind man to his deaf son in the dark closet.
Old 10-24-2009, 11:36 PM   #11
3r!c84
Badass
3r!c84's Avatar
hahahaahha never heard that one befor
-00 Saturn 5spd
1/4:13:90
Old 10-25-2009, 05:17 PM   #12
texasbigbear_wink
texasbigbear_wink's Avatar
Man (Drive Shaft King) In Dallas tx, Custom makes them and they are great at it.
texasbigbear_wink is offline   Reply With Quote
Old 10-29-2009, 05:42 PM   #13
1979blkchevy
do yo uknow if they have a website im seeing a phone nuber but no website
Old 10-29-2009, 07:41 PM   #14
texasbigbear_wink
Sorry I don't think so I looked myself but you may try to look for a shop that does that around you. If you cant find no other way.
87 Chevy R10 LB
02 Nissan Sentra GXE
