11-15-2009, 08:38 AM | #1 |
tightening up the steering
A few years ago I put power steering in my truck. At the time I put a small diameter steering wheel and was happy with the tension while turning. Recently I went back to a 16 inch wheel for the original look. The problem is that it takes no effort what so ever to turn the wheel. I was thinking I need to put a steering stabilizer on because of the tires I run. Any ideas out there? thanks, Cnut
11-15-2009, 10:47 AM | #2 |
its all about the +6 inches
Re: tightening up the steering
the pressure bypass valve spring is probably worn/broken.
on the back of the pump, where the high pressure line goes in, if you were to remove the fitting you'll find a spring in there. Yours is probanly snapped |
11-22-2009, 01:14 PM | #3 |
Is this spring easy to get to? Will it come out when I loosen the line fitting? And last thing, will the larger nut on the pump come loose? thanks for the help, Cnut
11-22-2009, 02:50 PM | #4 | |
20' Daredevil (Ret)
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
11-22-2009, 03:23 PM | #5 |
You may need to add some positive caster to your alignment. Make sure all steering/suspension components are not worn and in good shape. If you can not align it yourself find someone who will take the time to set it up right. I would suggest straight up (0 camber) on the drivers side and the same on the right side. For the caster go for as much positive caster as you can get. Approaching 4 degrees is good for straight line stability if you can get it. As for toe, only slightly in 1/16 in if you can get it. The alignment specs for manual steering will not be the same as power steering.
11-22-2009, 07:01 PM | #6 |
Thanks efabman, that never occurred to me. I was planning to get it aligned anyway. While I'm at it I'm just going to replace all the steering components, because I'm sure most of them are the originals. Was holding off on replacing a bunch of stuff because I was planning on a Disc brake Conversion, but have since decided against it. Just don't drive her enough to justify the cost. Again Thanks, Cnut
11-22-2009, 11:39 PM | #7 |
I have a lit of slop in my steering at lower speeds buton the freeway it's tight. Why does that happen?
11-22-2009, 11:40 PM | #8 |
I have a lot of slop in my steering at lower speeds buton the freeway it's tight. Why does that happen?
