Old 03-02-2010, 09:13 AM   #1
Scott Johnson
Junior Member
Scott Johnson's Avatar
WTB PTO adapter for NP205
I am looking for a PTO adapter that bolts to the drivers side of the NP205 transfer case, which allows you to run a PTO winch off of the transfer case.
71 C10 Step Daily Driver
72 K10 Suburban Work in Progress
www.louisianaclassictruckclub.com
Scott Johnson is offline   Reply With Quote
Old 03-02-2010, 02:32 PM   #2
V30 mongo
Re: WTB PTO adapter for NP205
You will have a hard time finding a PTO from a NP205. Most tow trucks and dump trucks used a PTO unit off of the transmission. Also if you use a single speed,non-reversible type and try to use the main transmission for speed and direction control the output shaft rotation in a forward gear must match the worm and gear (left or right) in the winch housing. If it is wrong your winch will wind in with the transmission in reverse.Your best bet is to get a reversible PTO such as a Chelsea model 340 or 352 and have the output shaft installed in the direction you want (forward or backwards). If you want a front mounted winch and you have a SM465 the model 340 is the best choice to install on the SM465. It's uotput speed is about 35% od engine speed in both forward and reverse. This will match the 40:1 worm ratio of most winches and line in and line out speeds will be the same.
V30 mongo is offline   Reply With Quote
Old 03-02-2010, 03:00 PM   #3
fun in dirt
fun in dirt's Avatar
Try Jackson Powertrain http://www.jacksonpowertrain.com/
We used them several years ago for a pto winch hookup & they are very helpful.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 03-02-2010, 04:48 PM   #4
Scott Johnson
Junior Member
I was hoping to find one to hook directly to my transfer case. I`ve never seen one, but I think they exist, right?
Old 03-02-2010, 05:48 PM   #5
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Not saying they're not out there, but every PTO I've ever seen on a truck has been operated off the transmission, not the transfer case. This is including 2 of our 1 ton dumps off of a SM465, one on our 79 Dodge (not sure of the transmission), and even on the newer trucks, the PTO would come off the Allison transmission in my 03 Duramax if I was to install one.
Edit: after a quick google search, it appears Muncie manufactured the PTO for the 205 transfer case for the military trucks in the 70/80s. Learn something new every day.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 03-02-2010, 07:10 PM   #6
darkhorse970
darkhorse970's Avatar
They do exist, I've had two of them over the years. They are hard to find these days though.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 03-02-2010, 10:32 PM   #7
6872xtc
6872xtc's Avatar
Are you wanting just the PTO drive? I have a complete drive, driveshaft and 12k winch so I was kind of thinking I would keep them together. I took it off of an '85 k30 I parted. The drive was nice and quiet. PM me, Dave
6872xtc is offline   Reply With Quote
Old 03-02-2010, 11:18 PM   #8
Scott Johnson
Junior Member
Wow Keith, wish you would have kept one. Dave, sent you a pm.
Old 03-15-2010, 08:27 AM   #9
Rod
Happen to see this NP205 with PTO on ebay, its a newer 1983 NP205 with slip yoke, there near same otherwise. This model PTO would work. Showing they exist thats all, this one is not mine.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 03-15-2010, 04:51 PM   #10
KrazyRay
KrazyRay's Avatar
You might want to try board member bikes & bowties up in WA. I sold him a pto cover because I think he might have taken the pto out and just needed the cover. Maybe a long shot, but worth a try.
KrazyRay is offline   Reply With Quote
Old 03-17-2010, 09:50 AM   #11
my67chevytruck
Under Construction
my67chevytruck's Avatar
Scott, PM sent.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-17-2010, 11:20 AM   #12
Scott Johnson
Junior Member
Thanks Heath
