Old 06-13-2010, 10:53 PM   #1
og350
og350's Avatar
stearing vibration/grown noise
so i used my dads 04 ext cab 4x4 this weekend and i am not impressed. when you turn to the left it has a vibration and power stearing noise. you can feel it in the wheel and it feels like it fights you to turn. but when you turn it back to the right not a single noise or anything nice and smooth! is it the pump or the gear box? it does it every time!!
og350 is offline   Reply With Quote
Old 06-14-2010, 07:18 PM   #2
truckdude239
truckdude239's Avatar
Re: stearing vibration/grown noise
probley the gear box going out
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-27-2010, 07:54 PM   #3
COBALT
COBALT's Avatar
If there's enough play in a steering box then yes, even if you have enough fluid pressure gear lash could make it seem like it's fighting the pump. However, if the pump is cavitating (air in the fluid causing the pump to run inneficiently) it can do this too. Check the fluid and see if you have bubbles. Also check the color of the fluid. When your hoses start to wear out they'll dissolve and change the color of the fluid, which can cause some funny behavior with the pump over time.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
