06-26-2010, 09:19 PM | #1 |
2004 sierra tie rod ends
Anyone ever replaced 2004 tie rod ends both (inner and outer)? Is it better left to the dealer or should someone with weekend skills be able to pull this off???
06-27-2010, 12:05 PM | #2 |
Re: 2004 sierra tie rod ends
well if its the same as a tahoe i did a guys at works in about 20 mins plus the 30 mins for alignment at the shop up the road. if it is 4 wd that are simple 2 wd not so much
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 06-27-2010 at 12:07 PM. |
06-28-2010, 03:23 AM | #3 |
So you are saying a two wheel drive is harder?
06-28-2010, 06:43 AM | #4 |
Yes
06-28-2010, 06:46 AM | #5 |
2WD HAS A RANK AND PINON which are harder to the fact you have to take the boots off the rack and have a special tool for it. the 4wd are right there on the outside where you can get to them it a big wrench it calls for .5 a side on the 4wd and 1.0 hour per side for 2wd
06-28-2010, 02:59 PM | #6 |
I have been reading up on it. Is it possible to damage the rack when removing the tie rod? What tool should I ask for at the parts store?
06-28-2010, 07:13 PM | #7 |
you need an innner tie rod tool http://www.harborfreight.com/inner-t...set-96558.html is what it looks like
06-30-2010, 11:41 AM | #8 |
What about the boots? Are they reusuable? Is there a special tool for removing/installing the boots? Thanks for all your help!!!!!!!!!!!!!!!
07-01-2010, 07:14 AM | #9 |
they are reusable if they are not ripped not special tool i just cut the clamp that holds them on the normally i use a zip-tie to hold them back on
07-02-2010, 06:56 PM | #10 |
07-02-2010, 07:30 PM | #11 |
yeah a small hose clamp would probley work better
07-03-2010, 10:03 PM | #12 |
A big Thanks to TRUCK DUDE!!!
07-03-2010, 11:11 PM | #13 |
did you get them done?
07-03-2010, 11:54 PM | #14 |
yep worked like a charm, thanks again
07-04-2010, 09:36 AM | #15 |
no problem glad i could help!!
