Old 12-06-2010, 12:34 AM   #1
BIGBLU 72
BIGBLU 72's Avatar
Head gaskets question
do i need to get bore specific head gaskets or will head gaskets for a 400 sbc support up to .030 over or do i need a to get head gaskets that have a max bore larger than the bore on my motor. Im asking this bc i have never had this motor apart and but im pretty sure that its stock bore with stock pistons
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 12-06-2010, 11:27 AM   #2
Lee H
Lee H's Avatar
Re: Head gaskets question
Stock head gaskets support the over bore. The Fel-Pro gasket package has the dimensions on it. I think the standard gasket bore size for a small block chevy is 4.100.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-07-2010, 12:23 AM   #3
Captainfab
60-66 Nut
You will have to get head gaskets specifically for a SB400. They have the steam holes unlike other SBC head gaskets. The bores of the gaskets will varl slightly. Just be sure you get gaskets with a bore bigger than what your block will be. And depending on what you're doing and how detailed you want to be, the compressed thickness is something to pay attention to as well.
