Elevation changes/jetting on the trail?
I was curious what you guys out there do when wheeling up into higher elevations with a carb. I just moved to Colorado and am anxious to go wheeling. The elevation at home is about 6000', and some of the trails out there have peaks in the 11,000' + range. I am running a q-jet, so changing jets and metering rods is not the easiest thing to do on the trail, but will be done if needed. What are some of the things you guys do?
72 K5 4x4 350 70 Nova 454 5spd 4-link |
Windy Corner of a Dirty Street
Re: Elevation changes/jetting on the trail?
I dealt with that for years. No matter what you do carburetors just don’t work well at high altitude. I gave up and went to fuel injection. Problem solved.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
Rottenwood Garage Member
Yep!
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
FI or diesel. Carbs are a pain for elevation changes. I ran up to Street Vibrations one year on the bike and had to change jets 4 times in 6 hours. Im all about the FI these days!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Run it on propane.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
K5Camper
![]() Join Date: Mar 2004
While I agree, FI is the way to eliminate the problem, I've had decent luck with my q-jet. However I don't fool around with changing rods/jets on trail. From my home altitude of 4800ft to 13,000ft all I've done is give a little bump in timing and couple hundered rpm increase in idle speed and it putts right along.
The thing is crawling along on the trail I'm not running WOT or even 1/2 throttle so making major changes in the rods/jets really wouldn't have an impact. The minor bump in timing is really more an improvement that I can feel. I just snug the dist clamp enough to hold it, but still allow a little movement if you bump it with the palm of your hand.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
#7 | |
Thanks for the feedback. I am still in the process of dialing it in from sea level. I think I may try a lighter power piston spring. I see you are from CO as well, we will have to get together for a wheeling trip!
#8 | |
K5Camper
Not sure the next run is, but probably it will be in the snow when we get some. DirtyLarry and I are south of you in Pueblo, but that's not all that far and there's some good trails not too far from all of us.
